Framework Desktop openSUSE Tumbleweed
Hello Folks,
Does anybody with Framework Desktop and openSUSE Linux installed?
Can you please let us know any problems or fixes that need to be done?
I plan to install Tumbleweed on the Desktop but first I need to get the mainboard I have ordered :wink:
I don’t have my Framework Desktop yet, but Tumbleweed works without bigger issues on HP ZBook Ultra 14 G1a (I think only camera doesn’t work, but I need to check this - maybe they fixed this), so I don’t expect any issues here.
Planning to at least try it, being in batch 11 someone will probably get to it before me. ROCm is probably going to be the slightly difficult part. I haven’t gotten it working natively on my current desktop.
I have installed Tumbleweed successfully. Not quite done with testing yet. I don’t get sound via DP and external monitor (but audio jack works). Could be a system setting. EDIT: It was the system settings, had to play around with them in the KDE system audio settings.
Otherwise I haven’t seen any issue so far.
