Framework Laptop 13 AMD 7840u temps
  • Windows 11 last release
  • Laptop 13 AMD 7040 Series 7840u
  • Bios 3.16
So after the last bios update, my laptop is getting really hot, like 100 degrees, Already changed my termal paste.
Using the battery it goes to 55 degrees. Power cable 100 degrees.
The heat pipe is really hot and I`m not seeing the fant speed up with the temperature, it takes like 2 minutes of the cpu at 100 degrees to start the fan.
This has honestly been the behavior of mine since the start, with all BIOS versions. The fan curve is just awful. It’s like Framework decided to prioritize silence at all costs.
you can adjust fan curve using tool created by one of the community member Framework Laptop 16 Windows Fan Control Tool (NEW GUI)!
