Framework Laptop 13 Ryzen 7040 - 25% boots fail
Hi,
I have a problem with booting my Ryzen based Framework 13.
Statistically 1 of 4 of cold boots (it not happens in sleep state) fails with message “BlInitializeLibrary failed 0xc0000185”.
If it happens I turn off device with power button and truns it on again and it boots normally.
Anyone have similar issue?
BL refers to the boot loader. I don’t think I’ve seen this error before in line with the system memory before but I would try a repair install on Windows and potentially rebuilding the boot configuration data (there are many guides with pictures available on google).
I would also try a reinstall of the Official framework drivers.
If the issue persists then I would try running memtest86+ from a bootable USB and check for failures with the ram (just a guess because the errors is showing on the same line as your RAM).
Make sure you have backed up all your data. This could indicate a failing disk/nvme.
For anyone who might have the same problem, I didn’t do anything and the problem disappeared on its own (after some time).
Time heals all wounds, as they say.
Anyway, when a customer comes to me with a problem, I put them off for at least a day, and in two-thirds of cases, they call back to say that the problem has resolved itself.
