I’d even take a touchpadless single piece palm rest, I’m usually using a mouse anyway.
And honestly this modular stuff was nonsense to begin with, should have been fixed with numpad for the 16, like a big version of the 13. That’d give room for taller modules, a laptop this size needing to grow a tumor for an Ethernet port is absurd.
I don’t think they will make an offset version, because it prevents you from placing the keyboard modules in all supported configurations (on the far right), which will definitely cause more support calls.
A better solution would be for them to update the firmware so that when either the keyboard or numpad’s brightness is changed, it syncs that change to the other piece.
Unless they find a clever way to make both the left-aligned and right-aligned versions the same SKU. Rotate it 180 degrees and now it works on the other side. Probably isn’t possible, but how cool would that be?
There’s not any way to do that without adding a direct connection between them and making one a slave to the other instead of an independent device connected to the computer.
I’m not a firmware programmer, so I’ll have to take your word for it, but at face value, that doesn’t sound correct. Is receiving a signal from device X and relaying it to device Y really outside the capabilities of motherboard firmware?
Looks like a great idea, I wonder if the drivers necessary to make that work will introduce much system latency if any. How well will linux recognise a connected external graphics card through this?
I think something like this will go great with maybe a 14.5-15 inches pro framework laptop (3:2) alongside a docking station where a graphics card and potentially extra storage or even an ethernet connection can be connected. I wonder if all of that would even be possible with that kind of connection, if so, it could remove the necessity for many people to have a laptop and a desktop.
Effectively, yes. They’re connected to the mainboard over USB as two separate keyboards. The only option besides making a pair which link and then present themselves as one USB keyboard and are managed by a single firmware, like a two piece keyboard (Such as https://keeb.io/collections/iris-split-ergonomic-keyboard), is to have software running on the computer which controls the backlight settings instead of the keyboard’s firmware.
I checked once the Framework site was back up after the announcement and they weren’t available yet. Here’s a snippet when looking through the coming soon section of the store.
Yeah, this is the combination I’ve been chasing for years. A thin and light 13" laptop when on the go, that can also be used for workstation tasks and gaming when at the office / home.
Having this connectivity in a 16" device is obviously great too, but a little less compelling, given it is possible to fit a powerful discrete GPU into such a form factor. Whereas that is next to impossible with a 13" device.
Arbitrary keyboard to keyboard communication is actually possible with a little trick. I use it with a qmk mouse. And a community member used it for a FWL16 keyboard firmware called altsync.
This is what I think is probably the biggest issue I’ve seen with the OCuLink connector being used. I’ve seen quite a few people who use the FW13 and who either use an eGPU or want to use an eGPU with their FW13. There’s currently no way to use the FW16 GPU with a FW13 (or any other Framework system). Also, there’s not hot plug capability.
Although given it’s a dev kit and not a full product I expect to see people modify it.
Is there an approximate date for when the One Piece Touchpad Module will be available? I still need a few USB-C modules and would rather not order twice
The one piece touchpad looks much better than with the little fillers! I’ll probably end up getting one as the configuration I’d really like isn’t supported. I have a numpad on the right and really wanted to have the touchpad on the right as well to stop my thumbs accidentally touching it, I was really disappointed when I discovered that this configuration isn’t supported. A version of the one piece with the touchpad on the right would be really appreciated!
