Framework Marketplace product entries that lack detail/need modification
There are a bunch of product entries on the Framework Marketplace that would really benefit from more details or that need some modification.
The entry for the 60W power adapter lacks details about the included detachable USB-C and AC cables:
For example how long is the USB-C cable? How long is the AC cable? Does it support PPS? What are its dimensions? For that one has to go to the blog post on the power adapter to find the answer to all these: for instance the length it specified there as 1m for the AC cable and 2m for the USB-C cable. Furthermore it should be mentioned that one of the ends of the USB-C cable is 90 degrees angled. Also the entry lacks a picture showing how the USB-C cable looks like.
