FW 16 - HDMI module not working - Fedora 41
With FW16 I see it’s connected, I can move it around in the screen config page. I only see things for perhaps one second though, then black screen. Once in a while I see the desktop, flickering then black sreen. It can happen for a minute or just once. I have tried placing it on slot 2 and 4, same result. The screen and HDMI cable work just fine. I can in fact connect my steam deck no problem.
Worth mentioning the DP port module works on both slot 2 and 4 just fine.
Running fedora41 live distro does not change a single thing.
Also worth mentioning my laptop flickers every now and then.
I do not test with the hdmi recently…
But for the flickering have a look her Screen flickering on Linux kernel 6.12 - #18 by Richard
It may (or not) have impact on the hdmi to…
hey thanks for your input. I just did that kernel part and it looks good so far.
The external screen flickers much less but it does constantly. I do not get black screen for longer than 2 seconds though.
Seems clear by now the problem is the kernel. As a matter of fact I have also tried a usb-c to HDMI adaper and I have the same results. It’s not the module, it’s not the cable.
What I have also noticed though is that when going hdmi to hdmi to same screen that’s connected and works fine with DP, also HDMI works fine. This is quite weird. To conclude it seems that outputting video (thorough HDMI) to the two samsung screens that I have it does not work. The screens though work fine with my steamdeck. Quite the thing.
