FW13 7840U not detecting TB hub (Debian 13 with 6.19.x backported kernel)
Debian
Which release version?
13 with backported kernel
Which kernel are you using?
6.19.6+deb13-amd64
03.18
FW13 7040-series
When I plug in a Thunderbolt 3 dock using a 80Gbps cable, nothing comes up either in boltctl or dmesg -w. This was also a problem before I switched to the Forky backported kernel, but was as far as I recall less of an issue with Bluefin.
I do get this though on boot:
[] ucsi_acpi USBC000:00: unknown error 0
[] ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
Power can also cut out from the charger sometimes when using the machine, but I don’t know if this is in any way related (this occurs over multiple cables and USB wall adapters).
Cheers.
I recognise those boot ‘errors’ but they don’t stop my FW 13 AMD 7040-series from working with my 40gbps Thunderbolt 3 cables.
Mar 24 09:12:55 fw13 kernel: ucsi_acpi USBC000:00: unknown error 0
Mar 24 09:12:55 fw13 kernel: ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
You might also need to check the release thread for the 3.18 BIOS on Framework 13 AMD 7040-series – a number of people are having isues with peripherals on USB4 docks at boot. It’s why I’ve not updated beyond BIOS 3.17, you might want to roll back to 3.17.
Sorry to kinda necro here, but I haven’t had access to a TB device in a few weeks. The 3.17 BIOS rollback didn’t fix the problem. It still charges, but charging (especially under load) is still intermittent, and TB data doesn’t appear to be working.
