Thunderbolt 4 dock not outputting, USB-4 errors reported
Fedora
Which release version?
Fedora 42
Which kernel are you using?
Linux 6.15.10-200.fc42.x86_64
3.04
AMD Ryzen™ AI 7 350
I have my Framework 13 connected to a WavLink Thunderbolt 4 dock. That dock has been working perfectly up until…15 minutes ago where, out of nowhere, it stopped supplying power and outputting my display to my monitor.
I ran sudo dmesg with the dock connected to the rear left USB4 port and a USB 3.2 flash drive connected to my front-right USB-A port and got this output
[   29.600723] Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
[   29.697523] rfkill: input handler disabled
[   48.895691] evm: overlay not supported
[   51.519628] usb 1-1: reset full-speed USB device number 2 using xhci_hcd
[   69.586048] ucsi_acpi USBC000:00: unknown error 0
[   96.683711] ucsi_acpi USBC000:00: unknown error 0
[  110.220637] usb 4-2: new SuperSpeed USB device number 2 using xhci_hcd
[  110.233271] usb 4-2: New USB device found, idVendor=0781, idProduct=55b1, bcdDevice= 1.10
[  110.233285] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  110.233288] usb 4-2: Product: SanDisk 3.2 Gen1
[  110.233290] usb 4-2: Manufacturer: SanDisk
[  110.233292] usb 4-2: SerialNumber: A2003AFF2B087479
[  110.280223] usb-storage 4-2:1.0: USB Mass Storage device detected
[  110.280573] scsi host0: usb-storage 4-2:1.0
[  110.280688] usbcore: registered new interface driver usb-storage
[  110.289818] usbcore: registered new interface driver uas
[  111.282445] scsi 0:0:0:0: Direct-Access     SanDisk  SanDisk 3.2 Gen1 DL17 PQ: 0 ANSI: 6
[  111.283196] sd 0:0:0:0: Attached scsi generic sg0 type 0
[  111.988558] sd 0:0:0:0: [sda] 244457472 512-byte logical blocks: (125 GB/117 GiB)
[  111.988970] sd 0:0:0:0: [sda] Write Protect is off
[  111.988980] sd 0:0:0:0: [sda] Mode Sense: 45 00 00 00
[  111.989374] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[  112.004614]  sda: sda1 sda2
[  112.005020] sd 0:0:0:0: [sda] Attached SCSI removable disk
[  190.880689] wlp192s0: disconnect from AP 3c:28:6d:c9:62:9b for new auth to 3c:28:6d:c6:71:b5
[  191.099915] wlp192s0: authenticate with 3c:28:6d:c6:71:b5 (local address=a6:16:13:25:5f:10)
[  191.116839] wlp192s0: send auth to 3c:28:6d:c6:71:b5 (try 1/3)
[  191.123669] wlp192s0: authenticated
[  191.128475] wlp192s0: associate with 3c:28:6d:c6:71:b5 (try 1/3)
[  191.152883] wlp192s0: RX ReassocResp from 3c:28:6d:c6:71:b5 (capab=0x1011 status=0 aid=5)
[  191.185662] wlp192s0: associated
[  191.240182] wlp192s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 3c:28:6d:c6:71:b5
[  446.348050] ucsi_acpi USBC000:00: unknown error 0
[  488.776656] usb 1-1: reset full-speed USB device number 2 using xhci_hcd
[  489.035689] usb 1-1: reset full-speed USB device number 2 using xhci_hcd
In addition while the indication sound tells me the USB-A flash drive is connected, it isn’t appearing in Files for access. Any help on this or solutions you guys might’ve had would be appreciated!
