FW16 Batch 10 Keyboard, Numpad, and Trackpad detected but do not work
Like the title says, I’ve had a FW16 for awhile now, but I’ve never been able to use it because all the peripherals will work for about 30 seconds, then stop for a minute, then work for about 30 seconds, repeat. After a day of debugging, they all stopped working permanently. Frameworks support is beyond worthless, so I’m trying to get the laptop working so I can sell it. What would I likely need to replace to get this working?
I’ve tried:
  1. using usb mice and keyboards - they work fine, even when onboard fails
  2. using only the keyboard or tackpad individually - no change
  3. trying the keyboard and trackpad in all possible positions - no change
  4. updating the bios - no change
other bits of info to help:
  1. issue happens in windows and linux
  2. issue happens with and without video card
  3. issue happens with no input modules installed
  4. if I leave the keyboard off, or the trackpad, I get the appropriate warnings, but if they are both installed and not working I do not get the warning
guess the support forum is as useless as the official support
How can people keep supporting Framework when they mistreat customers consistently like this? I’m not the only one who is having these issues.
