FW16 eGPU Experience
Hey friends,
For the most part, I’ve been very happy with the performance and stability of my (second) FW16, but I was running into some pretty constant crashes in DaVinci Resolve, so I decided to try out an eGPU. I’ve had the displeasure of using eGPU setups in the past and it’s mostly been an exercise in frustration, but I have been very excited by the possibility of the fabled Oculink expansion bay for this machine.
I was able to snag a cheap, Aliexpress eGPU for $50 on FB marketplace and decided to pick up an open-box PSU and GPU (4070ti S) at Microcenter to give it a whirl. I’m happy to say it has greatly exceeded my expectations. I did have one crash/disconnect early on, but I think it may have been due to the super cheap/sketchy TB cable that came with the eGPU. I swapped it out for a nice CalDigit cable and it’s been rock solid since then.
Resolve hasn’t crashed on me once and the performance has been delightful. Gaming prowess has been awesome as well. I’m running Valheim, BF2042, Helldivers 2, and OW2 at 4k with plenty of eye candy turned on (and DLSS when needed) and getting a steady and stable 70-90+ FPS. Another subtle distinction is that they feel like “desktop frames”, which sounds silly, but I feel like I can always tell the difference between desktop frames and laptop frames. You might be able to push the FPS with new gaming laptop hardware, but it never feels as smooth as a desktop. I haven’t done a lot of benchmarking, but achieved 17,500ish on my first and only Time Spy run.
Another nice advantage is that it allows me to leave the windows power settings on Balanced and though the FW fans still get cookin’ (tiger can’t change its stripes), it’s a lot less obnoxious than before. And–probably unsurprisingly–it doesn’t borrow juice from the battery while pushing the system. Had a really fun, 4-5 hour Valheim session with a friend the other night and everything was stable and sustainable.
I’m very happy with this configuration so far and even more excited for an Oculink future :).
Quick edit: I also wanted to mention that all 3 GPUs seem to be playing well together and I haven’t had to disable any of them in device manager. I’m only running my primary monitor through the eGPU and my dock/the iGPU are pushing the secondary monitor without issue.
Here’s a pic I snapped today of the makeshift setup.
And one more wholesome post on the forum! I love to see this after a day of troubleshooting user’s problems.
May I ask what OS you’re using? I haven’t been able to find an OS that has good eGPU compatibility. edit: missed the windows logo lol, eGPUs are a pain on linux :smiling_face_with_tear:
Very nice setup btw, it’s so nice that it almost looks like a 3D render!
Correct, good ole windows 11.
Thank you kindly! God bless f/1.8 :smiley:
If no one else is gonna say it, I will.
That’s a nice photo. I appreciate your effort in the composition and capture.
Hello, I would like to know what egpu support did you buy? . Is this valid?
https://es.aliexpress.com/item/1005007443996033.html
I would like to know what graphics card is compatible with the device?
What is necessary to connect the graph to the framework? The usb port?
Sorry for the delay, my friend. Looks like it’s this one https://www.aliexpress.us/item/3256804507814578.html?spm=a2g0o.productlist.main.3.769d4d432cGKFE&algo_pvid=c87910e5-b53e-4057-8b8d-8bc696f5ede1&algo_exp_id=c87910e5-b53e-4057-8b8d-8bc696f5ede1-1&pdp_npi=4%40dis!USD!200.00!88.50!!!200.00!88.50!%40210318ec17318668496751512eb662!12000037460961708!sea!US!0!ABX&curPageLogUid=0O2brbQ3H4NT&utparam-url=scene%3Asearch|query_from%3A
I’m using an Asus Pro Art 4070ti Super and it’s worked well so far.
I am using an eGPU on my FW16 from Day one as i migrated from a Lenovo Legion Go + eGPU Combo as a Main PC.
I am using the ADT-Link UT3G pcie4x4 USB 4 40Gbit Adapter which is currently the only Adapter where you can get the full 40gbit to be used by the GPU.
When i am stationary at Home its always plugged into my RX6800XT.
My Setup on eGPU.op
My 3D Mark PCIE Benchmark
My 3D Mark TimeSpy Result
My 3D Mark Steelnomad Score
It is a Great Setup i use mainly for VR Flight Sims.
Thanks friend
And this?
https://es.aliexpress.com/item/1005006121040283.html
What GPU do you want to use? AMD or Nvidia? Take the ADT-Link UT3G in either Case. It can not charge your FW16 but it is the best performing of all current available eGPU Adapters. With AMD its Plug and Play and when you want to use an Nvida Card you need the Error 43 Fix as of my knowledge. Could be be obsolote with the current Windows 11 Release.
Hi! Is it that an awful idea to use egpu with integral monitor of fw16? Maybe you can link me a thread because I couldn’t find much info on it. Happy 2025!!!
You loose a good Portion of the eGPU Performance when using an internal Screen instead of one connected directly to the eGPU. My Timespy Score went from 16480 to about 13k with an RX6800xt eGPU. If you are on a lower Tier eGPU this Gap gets smaller.
Edit also a Happy new Year :slight_smile:
