FW 16 - Linux / Kubuntu 24.04LTS
The laptop keyboard is stuck at layer 2 and does not come out from it.
I am using https://keyboard.frame.work and I can set keys. On layer 2, I set “Numpad 2” to key “Q” for testing purpose. With keyboard test, I can see “N2” pressed with “Q” key.
I then set “TG(2)” on spacebar and press once. No go.
Also “TG(2)” on enter, and press enter. No go.
I removed the keyboard, and put it back. No go.
Saved and loaded the layout. No go.
Any suggestions to try?
ETA - I loaded the original default layout and it seems to restore. I lose the things I set up but better than stuck at layer 2. So, maybe do over is an option.
