I have a problem with the keyboard. Help
I have a problem with the keyboard. Help.
When I press keys like 1, they don’t show the correct key. For example, when I press the 1 key, the L appears.
Or, for example, when I press Y, the " symbol appears.
I’ve tried disabling the keyboard, or reselecting my country’s keyboard settings in Windows, or disabling and re-enabling the keyboard, but that doesn’t fix it.
When creating a topic, use a product tag (and a secondary tag if applicable).
For Linux-related issues, use the “Framework Laptop 16 Linux” subcategory.
If you have a hardware/software issue, please post it under “Community Support” category.
Try checking your keyboard’s config here: https://keyboard.frame.work/
You’ll need a chromium browser to let it connect, but it should show you your keyboard and what keys are assigned where
Thanks!!!Solved
