Hi,
This is a comment on the FW16 Sound Quality.
I have been hearing vibrations and distortion to the sound when turned up to 80% +
I was curious where this problem was coming from so I simply added some vibration absorption material between the laptop and the desktop it was on. No changes to the insides of the FW16 laptop. In this case, it was a thin bit of foam type material that comes as the material encasing some laptop types when in the delivery box. So, low cost.
Summary:
It has fixed the problem for me.
So, if users are hearing sound distortion or vibrations, it might be worth considering what the laptop is resting on, and adding some vibration reducing material between the laptop and the surface it is resting on.
I guess a minor improvement to the FW16, might be changing the feet of the FW16 to a material that absorbs vibrations better, thus maybe removing my need for the foam type material.
