So TLDR; my GPU is supposedly getting insanely hot and using basically 100% when opening most games suddenly, and naturally the performance tanks. Any ideas why? Full context below.
I was gaming with a friend (playing Granvir) and everything was fine, performance was normal, no abnormalities. We finish gaming and I open my browser (Which has like 50 tabs, normally isnt an issue), which as soon as I clicked to my email tab the entire laptop begun to freeze, though I could still hear through Discord vc. I decided to force shut down the laptop via holding the power button. I noticed Discord pings and other things begun functioning as I was turning it off. Eventually turned it off and rebooted. Thought everything was fine until I tried booting a game shortly after, the game performance was surprisingly horrible. I restarted to try again and it was still bad. I booted up other games to try and this is when we started to notice the majority of games caused the GPU to go extreme: Fans racing, 95% usage, 90+ degrees celsius. I turned it off and cleaned out dust and hairs from the fans and vents. Reboot, issue is still there. Is my GPU the problem? Whats going on?
(Im gonna immediately go to support with this too, just wanted to see what the community thinks)
