Graphics options for playing Cities Skylines 2
Hi community - I was interested in your thoughts on this.
I’ve got the Framework 13 Ryzen 7840U model on preorder. In most regards this laptop is perfect for me - solid Linux support, and I like the form factor of the smaller laptop. I’ve been an XPS 13 user for years and this feels like the natural progression.
I’m not really a gamer except for Cities Skylines 1, which plays just fine on my XPS 13 (i7 7560U with no GPU).
I’m excited about Cities Skylines 2 and wondering if I’ll be able to play it on my new Framework. They say the minimum requirement is a Radeon RX 470 and according to this: 780M vs RX 470 [6-Benchmark Showdown] it is a slightly higher spec than the integrated GPU.
I’m not really interested in the Framework 16 even though I know it would be an easy solution, since gaming is such a small part of what I will use the laptop for. What other options are available to me? I see eGPUs don’t really work yet. If you were me, would you just buy the game and dial down all the graphics settings and hope for the best?
Have you considered a Cloud gaming solution like Shadow.tech, or Xbox play anywhere?
You should be fine as long as you turn down your resolution a bit!
eGPUs should work as well, as the USB4 is full-featured on the Framework laptop!
@Eric_Lidiak Ooh I hadn’t but I will take a look - that might be the obvious solution!
@Shiroudan Well that’s an exciting prospect! I’ve seen in other threads they’re pretty flaky on earlier Frameworks and definitely not officially supported, and me being a Linux user makes that even more likely. It’s a big investment if it doesn’t work so I will wait and see what other people’s experience is once these Ryzen models are out in the wild!
