Hey Guys i wanted to share with you the Use of the Clear ANSI Keyboard with a German Key Layout.
First of all i ordered Keyboard Stickers from Keyshort
They arrived within 2 Weeks and are phenomal Quality.
I ordered the Framework Laptop 16 + RGB Macro Pad Full Key Set.
Application was pretty easy.
They are semi Translucent and the Symbols are fully Transparent.
Problem with the Keyboard, the missing <>| Key in Comparison with the Real German Keyboard.
To Help with that Issue Keyshorts provided the YXC Key with the added Symbols.
The biggest Problem is, that the German Layout doesn’t know those Keys with those Symbols.
I created a Custom Software Keyboard Layout with MSKLC to accomodate this. Right ALT with YXC will create <>| if this Layout is Applied in Windows.
I provide the File as a Setup from my Google Drive. If you want to use it you can just Trust me or send the Zip File a through a Virus Scanner.
Unzip it and run the Setup.exe, Done!
Feel Free to Share
