See the video of the error in the Reddit post. Comment/information below copied from Reddit.
Recently, I picked up a Satechi 4 port USB-C charging station, and it’s a great little charger that works with all of my devices, except my Framework laptop. I initially suspected this to be an issue with the charger, so I contacted Satechi support and they swapped my unit with a replacement. Unfortunately, the problem remained.
In this video, I test a Dell laptop, a MacBook, and two Framework laptops. Both the Dell and Macbook test okay, but the Frameworks do not. I suspected this could be an issue with how The Framework laptop has trouble charging at 15V, but this charger should be pushing it to 20V so that point should not be relevant. Regardless, I had one of the laptops on BIOS 3.10 and the other on BIOS 3.07, and both displayed the same fault.
Does anyone have any recommendations for what could be causing this problem, as well as how I could go about fixing it?
