I recently got a Framework desktop and installed bazzite, however the desktop is not detecting my second monitor. I’ve searched through the posts here and found one saying I needed an “Active Adapter”. However when I look that up they are all saying that the HDMI is what you plug into the desktop itself, but there is only one HDMI port on the desktop.
If anyone has any recommendations as to what I should do or if I’m somehow looking at things backwards, any help is appreciated.
I’ve found an active adaptor that does infact fix the problem. The monitor itself was HDMI so I could not just use DP to DP, and my HDMI to DP also did not work, however HDMI to HDMI with an adaptor works.
