Hi everyone! Back again to report that the Amazon stuff arrived today and works pretty well!
Here’s the test environment details:
Intel Core i5 1135G7
16GB DDR4 3200
Windows 11 Pro
1TB Crucial P3
100% battery with 65W AC adapter.
Tests performed on a marble surface with 3 passes of the same benchmark (3DMark Night Raid) each. Previous TIM was Arctic MX-6.
With the MX-6, the CPU often dropped from full boost as shown in this particular run:
In fact, there are some cases where the CPU hit almost 95 degrees celcius and disasterously throttled to 500 MHz!! Unfortunately, I misplaced the temp graph for this but the frequency graph really speaks for itself.
With the PTM7950 the CPU frequencies smooth out and I haven’t seen any huge throttling, however it is still there in the end of the CPU specific test.
Temperatures peak at around 85 degrees rather than the low 90s like with the MX-6.
(EDIT: Hmm, looking at this again it looks like this doesn’t even boost past 4 gigahertz like before! This is odd, but it might just be a one off thing. I’ll run a few more tests!)
All in all I’d say this stuff is pretty legit! I have to say though with my regular workflow I would never really get the original TIM to thermal throttle, but it is nice to know I have some of the best stuff out there in my computer. It is quite expensive, so while it’s nice to do I don’t really think it’s a must have. It’s not like I’m always running benchmarks on my laptop or anything
For those who have been waiting for a more reliable source before taking the plunge, I can vouch for the product I received on Amazon, would be great if you’re constantly doing CPU intensive tasks on higher end laptops where thermal throttling and noise is a real issue!
EDIT:
After a couple of heat cycles, I decided to go for an AIDA 64 stability test as others have done above. Looks like the results I’m getting line up pretty well here, with just a little bit of throttling at the beginning.
It’s unfortunate that I didn’t have results from the MX-6 thermal paste I had in there before, but I seem to recall people mentioning that repasting over the stock paste didn’t make much of a difference, so I assume there would have been a fair amount of throttling there in that case. (If another 11th gen i5 user can comment on this one, that would be great!!)
Overall my conclusion doesn’t change, this is some pretty potent stuff! I’m gonna be putting it in everything now, heh.
