How can I check if I have a 1st or 2nd generation display?
Specifically this: https://frame.work/de/en/products/16-display-kit?v=FRAKKM0001
Which Linux distro are you using? NixOS
Which release version? unstable; last updated a few days ago
Which kernel are you using? 6.19
Which BIOS version are you using? 0.0.4.3
Which Framework Laptop 16 model are you using? AMD Ryzen™ 7040 Series
framework laptop with AMD Ryzen 7040 series comes with gen 1 display and displaykit.
Gen 2 is preinstalled on new AMD Ryzen 9 AI 300 series framwork 16 laptop. So that laptop is called Gen 2, while yours is called Gen 1.
