How convertible is the Framework?
I have the framework 13 AMD. I want to convert it to a Chromebook, ChromeOS not ChromeOS Flex, how can I do it?
This is the project that comes closest to your goals Brunch.
No guarantees that it works, ChromeOS is very picky with hardware.
The official solution that would be guaranteed to work would be to buy the Chromebook motherboard and maybe change some other components as well (information about what else might need to be changed is here, afaik that knowledge base documentation never got posted).
Trying to do it on your existing hardware without ChomeOS Flex may be a bit tricky. @Shiroudan mentioned the way to try to do that.
