Will use Bazzite
Which release version?
Idk. I don’t use Linux yet. Just hope to when I buy the laptop
Which kernel are you using?
I would use whatever the latest stable version is
I don’t have the laptop yet. Do I even have to be answering these questions?
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
Will be AI 300 with the 7 350 chip
I just want to know how well the 5070 does on Bazzite compared to the 7700S. Is it a pain to work with? Edit: I asked Reddit and I got very mixed responses lol
