My laptop feels consistently hotter than it should be. How can I confirm that my fan is working?
Hello There,
If you’re feeling ballsy, you could pop open the laptop, keep the KB & Co. attached with the connector and hit the power button. Fan should go whrrr then, would be able to see it, too!
Best Regards,
Varg
Thanks for the prompt replies and suggestions.
My DIY has 1185-G7 CPU with 64 GB RAM and Windows 10 Pro. I use it for a lot of large Excel model builds.
What can I use to determine how warm it is getting? Is there some type of “laptop thermometer” I can use?
Yes! There are many programs dedicated to reading hardware information!
HWiNFO64 is the general to-go for pros, although Throttlestop can also read temperature as well as provide functionality to lower it!
It’s also possible to read the fan speed. Howett wrote a good description here. If there’s interest, I could share a Python script that eases polling of the fan speed.
