I'm having issues with my Framework 13 7040u going into a deep sleep and sometimes crashing when it wakes up
I’ve been using the laptop for about 3 months now but I have one issue that has been driving me crazy. When I let the laptop sit for a couple of hours the machine will go into a deep sleep mode and when I open it I have to press the power button and it takes me to the Framework logo and then the windows log in screen pops up. Most of the time I can log in and resume my progress but about 1/10 times windows crashes and I have to reopen all of my programs with a fresh boot.
My graphics drivers are up to date downloaded from the AMD site and I reinstalled the BIOS driver and the bundle of drivers from the framework website. Could this be an issues with windows modern standby? I am running Windows 11.
I feel like I’ve tried everything and the problem still persists, I was wondering if anyone else had this problem.
You can go into your power settings and disable the laptop from going into hibernation or suspend. This will prevent that happening. Why you are having failed hibernation sessions 1 out 10 times, I can’t speak to. Are you using a NVME drive that was provided by Framework?
Yes, the drive is straight from framework.
Ideally I would like to close the laptop lid and have the computer go to sleep so it won’t get hot in a backpack.
Heres a link to the windows sleep study.
During standby this is possible, but for the best chances of Windows not causing a cooked laptop, you would use hibernation.
Your sleep study shows typical behavior for a S0 enabled laptop. S0 stands for Modern Standby. It basically is a low power state that allows the computer to still do things, like run updates.
If possible (I say this because I only have Intel based Framework mainboards) I would switch to S3 if AMD supports it.
Under S0 it will sleep until 5% of your battery has been used, where it will then hibernate. Using S3 wont do this. It will sleep until the battery is dead.
Hibernation is really the ticket here. That is what I recommend using.
I’ll try out s3
I am also having this issue with my Framework 13 AMD (7040 series) I got in November last year at work. S3 is not supported on this processor, so disabling S0 just leaves you with hibernate.
It is extremely frustrating. I get up from my desk (unplugging USB C dock) and bring my laptop with me to help a user, and a lot of the time when I open the lid again it has crashed and I am greeted with the Framework logo.
Tried to look into updating the WD NVME SSD firmware, but the WD Dashboard app doesn’t open. Not sure what to do.
I have seen a problem where my FW16 laptop freezes if I unplug a thunderbolt device while the device is suspended.
So you might work around the problem by unplugging the usb c dock before you suspend.
You can change the actions when you put the computer sleep to just hibernating from the get go. This will avoid the sleep to hibernation issue and it literally adds seconds more to the process. As an added bonus Windows hibernate only writes the minimum necessary to bring the computer back from being woken up.
It has been a known issue with AMD Framework laptops that sleep and sometimes sleep to hibernation does not work right all the time. Just stick to hibernation and this will be avoided all together.
