Initial audio delay present when using framework13 intel core series 1 with WD22TB4 Dock
I am seeing or “hearing” an audio delay when I use my framework13 with the WD22TB4 dock. The reason I am using this dock is because I already happen to have it for my WFH dell PC (which btw doesn’t have this issue).
The issue is that when I start playing a video the audio will not be there for 2-3 seconds. Then the audio will “turn on” as if it were on the whole time. This doesn’t happen 100% time but happens pretty often.
I tried this solution but it didn’t seem to work: Solved: Re: System Sound Delay - Page 2 - HP Support Community - 6224970
Another suggestion I found on the internet but I can’t find a similar setting: ElegantWin1694 comments on Few seconds audio delay when connected through HDMI/DP
I should have the latest framework13 drives and latest dock drivers
This is on Windows 11
There are no audio delays of any kind when not using the dock
Any thoughts? Thanks.
I also tried unchecking the “make this device exclusive” (this device being my monitor) but that didn’t work as well.
Update unchecking “Allow the computer to turn off this device to save power” on all the Generic USB Hubs in device manager did not work
The issue is still occurring. At this point I am thinking of getting a new dock.
At this point I can confidently say that dell docks do not work with frameworks
I use a WD19TBS, the Thunderbolt 3 variety of the same dock albeit without an onboard audio chip (that’s what the S indicates) and have had no trouble with it on either my original 11th gen Intel or first-gen AMD laptops.
My monitor has an audio output that I plugged my speakers into and it has no startup lag when I begin playing sound. I just selected HDMI/Displayport for the audio output and it worked fine. I run Linux though, not Windows.
Have you tried a different USB audio interface? Have you updated the firmware on the dock?
What do you mean by this like? Like using headphones plugged into the framework?
This is definitely a powersaving issue. Somewhere along the line, something is being turned off to save power. I run into this myself with a non-Framework (in my case, it’s on the desktop with a USB-C IEM cable, but I only run into this when I first plug it in b/c it takes a little bit to turn on), so it’s not Framework-specific, though the Framework design might be causing issues you don’t run into with your other devices.
At this point, I don’t know enough about Windows to help you debug further, unfortunately (I use Linux exclusively on my personal devices), but I know the issue you are describing. You need to check the powersaving settings on every part of that pipeline — for some reason, the power is getting turned off at some part of the pipeline, causing your issues.
