Input deck doesn't work when trackpad is installed on the right
  • Which OS? Windows 11 Pro 24H2
  • Which Framework product? Laptop 16, AMD 7040 Series
None of the input modules work when the trackpad is installed on the right side. I’ve tried it with spacers and the num pad. I would like to be able to put the num pad on the left so I can enter numbers without having to take my hand off the mouse. According to the this guide, it’s supposed to work.
I’ve tried reseating the mid-plate cable with no success. Any other ideas?
I vaguely remember someone else having a similar issue not long after the Framework Laptop 16 was finally out. I do not remember what the solution was or if there was follow up on what corrected the anomaly.
I thought they were trying to use the trackpad on the right but it might have been a case where it only worked in the center. Some suggested looking at the connectors (pogo pins) and cables on the mid plate. You might want to contact support to start a ticket and see what advice they have. Surely someone has run into a similar issue before. Let us know how it turns out. :grinning:
I’ve filed a support ticket, we’ll see what turns up.
Support determined that the mid plate needed replacing, so they sent it.
