Issue with installing Audio driver
Following is my system information:
OS: Microsoft Windows 11 Pro
Laptop: Framework 13 13th Gen Intel Core
I have updated drivers by running following budle Framework_Laptop_13_12th_and_13th_Gen_Intel_Core_driver_bundle_W11__2024_06_25.exe.
I am having issue installing Intel High Defination Audio driver and getting error “Windows was unable to install your Intel High Defination Audio”.
I uninstalled the driver and restarted the system, but keep getting the same error after restart. I did not have this issue prior to installing the bundle.
I appreciate if someone could help me out identifyiing the issue
2024-12-18T05:00:00Z
I am also having the same exact problem. No matter what I do with the driver, it keeps its yellow exclaimation mark and is recognised as “other devices”. Framework 13, 13th gen intel Core, win11 pro.
Did you get any help related to your audio device?
I’m having the same issue (only just saw this thread) and posted into this other thread (which I suspect is related) - also no solution sadly.
