I’m running Linux Mint Cinnamon (edge) on my DIY i5 FW. Everything is working good except for 2 small things -
First off, my USB-C hub that I’ve been using on a 2019 Macbook Pro doesn’t work right on the Framework. The regular USB ports on it work, but I can’t use the HDMI out or charge from it. Leading from having 1 thing plugged in to having 3. Is there a cheap TB3 or USB-C hub that supports HDMI 2.0 out and can pass a charge in?
Second thing is that my WiFi speed is absolutely horrendous. On a lucky day I can get 5Mbit down. Usually it’s around 1Mbit. On my phone or macbook in the same spot I get ~300Mbit on average. Could this a kernel issue or something on 5.11?
