Hi!
I wonder if it would be possible to use 74wh for the Laptop 13 non-pro. today I have 55Wh with AMD Radeon 760M. What would be the limiting factors? The location, size or the power port?
Thanks for your answers ![]()
Hi!
The new battery wonβt fit in the old bottom case, so you will need to get the pro chassis to be able to fit the new battery in there
Here is a link to the part compatibility chart Framework came up with.
They had to change the geometry of the bottom cover, and I think even the input cover, to fit the larger battery and larger speakers. Unfortunately, that means a lot has to change to upgrade to the larger battery.
Edit: Also, welcome to the community!
Edit 2: Itβs not a very big capacity jump, but the 61Wh battery is a direct swap with the 55Wh. Just FYI.
