CAD file for Framework Laptop 13 Pro battery?
I’m working on a project that will use a 13 Pro mainboard and 74Wh Pro battery outside the stock chassis. I noticed that the current Framework GitHub repo has CAD files for the older Laptop 13 battery, but I do not see a standalone CAD file for the Pro battery.
The Pro battery is cited as being geometrically different from the standard Laptop 13 battery. The standard pack is listed as 61Wh and 239mm × 6mm × 93mm, while the Pro pack is listed as 74Wh and is only compatible with the Pro Bottom Cover and Pro Input Cover.
Will we get a STEP file or simplified envelope model for the 74Wh Pro battery? Even just the external dimensions, mounting points, connector location, and keep-out areas would be useful for developer projects.
As a stand in I have copied the features/dimensions from the Pro case that accommodate the battery into my design, however I would still appreciate a CAD model for the Pro battery itself to confirm fitment.
