Do we have a memory vendor qualified list? Or do we know what speeds we should be using? Trying to get the most out of my laptop…
There are 2 knowledgebase article
What DRAM/memory is supported by Framework Laptop 16?
What DRAM/memory is supported by Framework Laptop 13 (AMD Ryzen™ 7040 Series)?
Yeah, and as far as has been reported, the 24GB/48GB SODIMMs have been working fine on the FW 13 AMD, so I’ll be going with the 2x48GB sticks. Unless they release 64GB ones in the next couple of months before my Batch 12.
There’s also [DDR5 ONLY] RAM Survey - Framework Laptop 13 (AMD Ryzen 7040 Series) and Framework Laptop 16 DIY, so you can see what others are running (apparently) successfully.
using 4800 sticks from a former laptop and it seems fine, will get 64gb of 5600 next payday…
