I was wondering what 64GB kit I should get for the Framework 16 laptop I am getting. Does anyone have any suggestions?
Have trhis one: Kingston FURY Impact PnP 64GB (2x32GB) 5600M DDR5 CL40 SODIMM - KF556S40IBK2-64 on mine, and it works really nice.
if you can wait, the framework marketplace lists refurbished ram periodically. you could put in an alert for the 32gb modules. if you go that route, i recommend checking the page daily and buy immediately. you will likely see the modules in stock before the email alert is sent to your inbox.
I got the same, works really well
If this question is about vetted RAM for the FW16 7040 boards:
The AI 300 boards for FW16 don’t have that info published publicly yet.
I can vouch for G.Skill Ripjaws DDR5-5600 CL40-40-40 1.10V SO-DIMM
