System information and related issue (unresolved as far as I know).
- OS: Windows 11 Home 64 bit (10.0, Build 26100)
- Framework 13, AMD Ryzen 5 7040u series
- On latest firmware (the battery life extending feature release)
- Related topic: https://community.frame.work/t/hot-and-unable-to-turn-off-on/5927/22
Recently, as in the past 2 months, I’ve noticed my laptop has been having potentially dangerous overheating issues. I’ve had the laptop for over a year now, and it only gets light use (usually my device to remote into work or watch youtube). This is extremely worrying as it seems it may get so hot the device could have a catastrophic failure and result in a fire. I have never had this issue before
What happens is that I will close the lid or manually put it into sleep mode, and put it away (always in a breathable location, often on hardwood table or wooden shelf). I will come back some time later and the bottom section near the battery/ above the keyboard, below the hinge, will be so hot to the touch you would have trouble touching the heated part for long. The fan is not running, and the laptop itself is stuck on a black screen, presumably bc it has locked itself up due to overheating. I’m able to force a shutoff by holding the power button and turning it back on will allow the fans to kick in and cool fairly quickly. I experienced this issue before and after updating the firmware, so I doubt that update is the culprit.
Anyone else recently encountering this issue or found a solution? The related thread seems to be dead with the last activity in 2023 with no resolution as far as I can see…
