I recently experienced that my Framework Laptop wakes up from sleep (hibernation in Windows 10) when i move my external mouse or press a key on the external keyboard. The touchpad or keyboard from the laptop itself does nothing. Is this expected behaviour? I accidently reactivate my laptop often. Does anyone know a way to deactivate this?
I know about the differences in sleep and hibernate mode. But the case for me with hibernation activated the laptop it reactivates just when i move the external mouse or press the keyboard which is not what i want.
I just tested sleep and for me it seems like it just does nothing else than switching the display off. Fan keeps spinning and even the keyboard backlight stays on.
Short update:
I solved the initial problem about my external keyboard and mouse waking up the laptop from hibernation. I solved it by deactivating the option “Allow this device to wake up my PC” under Device Manager → (select your device) → Properties → under Power Management.
But still:
As far as i understood the only difference between sleep and hibernation is, that sleep keeps the RAM under power and hibernation writes the current RAM to the SSD right? So sleep should also put the laptop into an “almost off” state?
