Ledmatrix: timeout error?
Ubuntu 24.04.1. I downloaded the inputmodule software. I also added the udev rules and run $ sudo udevadm control --reload && sudo udevadm trigger as mentioned in the readme:
$ ls -l /etc/udev/rules.d/50-framework-inputmodule.rules
-rw-r--r-- 1 root root 446 Nov 30 22:34 /etc/udev/rules.d/50-framework-inputmodule.rules
inputmodule runs and detects the led matrix input modules:
$ inputmodule-control -V
inputmodule-control 0.1.8
$ inputmodule-control -l
/dev/ttyACM0
  VID     0x32AC
  PID     0x0020
  SN      FRAKDEBZ0100000000
  Product LED_Matrix_Input_Module
/dev/ttyACM1
  VID     0x32AC
  PID     0x0020
But when queering the modules, I receive a timeout error message:
$ inputmodule-control led-matrix -v
thread 'main' panicked at 'Found no data!: Custom { kind: TimedOut, error: "Operation timed out" }', inputmodule-control/src/inputmodule.rs:352:10
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
Call including full backtrace (`RUST_BACKTRACE=full`)
Device Version: 0.2.0
stack backtrace:
   0:     0x64a51b9c4ad0 - std::backtrace_rs::backtrace::libunwind::trace::ha9053a9a07ca49cb
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/std/src/../../backtrace/src/backtrace/libunwind.rs:93:5
   1:     0x64a51b9c4ad0 - std::backtrace_rs::backtrace::trace_unsynchronized::h9c2852a457ad564e
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/std/src/../../backtrace/src/backtrace/mod.rs:66:5
   2:     0x64a51b9c4ad0 - std::sys_common::backtrace::_print_fmt::h457936fbfaa0070f
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/std/src/sys_common/backtrace.rs:65:5
   3:     0x64a51b9c4ad0 - <std::sys_common::backtrace::_print::DisplayBacktrace as core::fmt::Display>::fmt::h5779d7bf7f70cb0c
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/std/src/sys_common/backtrace.rs:44:22
   4:     0x64a51b96501e - core::fmt::write::h5a4baaff1bcd3eb5
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/core/src/fmt/mod.rs:1232:17
   5:     0x64a51b9a0ae4 - std::io::Write::write_fmt::h4bc1f301cb9e9cce
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/std/src/io/mod.rs:1684:15
   6:     0x64a51b9c5fd7 - std::sys_common::backtrace::_print::h5fcdc36060f177e8
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/std/src/sys_common/backtrace.rs:47:5
   7:     0x64a51b9c5fd7 - std::sys_common::backtrace::print::h54ca9458b876c8bf
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/std/src/sys_common/backtrace.rs:34:9
   8:     0x64a51b9c5d75 - std::panicking::default_hook::{{closure}}::hbe471161c7664ed6
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/std/src/panicking.rs:271:22
   9:     0x64a51b9c635a - std::panicking::default_hook::ha3500da57aa4ac4f
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/std/src/panicking.rs:290:9
  10:     0x64a51b9c635a - std::panicking::rust_panic_with_hook::h50c09d000dc561d2
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/std/src/panicking.rs:692:13
  11:     0x64a51b9c6184 - std::panicking::begin_panic_handler::{{closure}}::h9e2b2176e00e0d9c
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/std/src/panicking.rs:583:13
  12:     0x64a51b9c60e6 - std::sys_common::backtrace::__rust_end_short_backtrace::h5739b8e512c09d02
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/std/src/sys_common/backtrace.rs:150:18
  13:     0x64a51b9c60d1 - rust_begin_unwind
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/std/src/panicking.rs:579:5
  14:     0x64a51b8c6d32 - core::panicking::panic_fmt::hf33a1475b4dc5c3e
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/core/src/panicking.rs:64:14
  15:     0x64a51b8c70a2 - core::result::unwrap_failed::hdff5465d74574b44
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/core/src/result.rs:1750:5
  16:     0x64a51b8fcd89 - core::result::Result<T,E>::expect::h09ad2071d782a90c
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/core/src/result.rs:1047:23
  17:     0x64a51b8fcd89 - inputmodule_control::inputmodule::get_device_version::hb190c9fd686275ce
                               at /home/runner/work/inputmodule-rs/inputmodule-rs/inputmodule-control/src/inputmodule.rs:351:5
  18:     0x64a51b8f85fd - inputmodule_control::inputmodule::serial_commands::haded42d84a5f6028
                               at /home/runner/work/inputmodule-rs/inputmodule-rs/inputmodule-control/src/inputmodule.rs:241:21
  19:     0x64a51b8ff147 - inputmodule_control::main::hd73c270150b5884e
                               at /home/runner/work/inputmodule-rs/inputmodule-rs/inputmodule-control/src/main.rs:63:20
  20:     0x64a51b8e18c3 - core::ops::function::FnOnce::call_once::h60cafe144945ca54
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/core/src/ops/function.rs:250:5
  21:     0x64a51b8e18c3 - std::sys_common::backtrace::__rust_begin_short_backtrace::hf44eaa5f7d26e481
                               at /rustc/84c898d65adf2f39a5a98507f1fe0ce10a2b8dbc/library/std/src/sys_common/backtrace.rs:134:18
  22:     0x64a51b917789 - main
  23:     0x7dae6522a1ca - __libc_start_call_main
                               at ./csu/../sysdeps/nptl/libc_start_call_main.h:58:16
  24:     0x7dae6522a28b - __libc_start_main_impl
                               at ./csu/../csu/libc-start.c:360:3
  25:     0x64a51b8c9d55 - _start
  26:                0x0 - <unknown>
Any help, what did I miss?
So I did create a github issue, and it seems I’m not alone and the issue might be a little mit more complex.
