LTE Cat 4 Cell Modem Card
If you need some 3D printed parts I can print &ship them to you.
Sounds great. Or if you wanted to experiment with the design yourself, I could send you the other prototype PCBA for testing.
yeah for sure! once i have it, i’ll try sketching a case for it.
I’ll use Onshape as the CAD tool, so anyone can edit the file later if needed.
Just shoot me a pm where I can pay you for the prototype board.
Cool! Seems there is definitely at least enough interest for a meaningful EU(rope) production run. I’d probably wait a while for some more real-life testing with the prototype unit.
Leaving case work to @FelixL for now.
Regarding antennas: this seller seems to have a decent selections of MHF4 4G PCB/FPC antennas, including various cable lengths from 3cm for fitting into expransion card to 20cm for routing it all the way to the top of the display.
https://www.aliexpress.com/item/1005008131732495.html
One option to consider might be to have the main antenna in the bottom bezel next to the wifi antennas and the diversity antenna inside the expansion card at the bottom side.
The GNSS antenna, if present, would just stick out of the expansion slot, which it needs to anyway to get a good view of the sky.
My provisional testing setup :laughing:
Interesting that this antenna placement tanked upload performance but did not affect download much.
Great job on the progress! Antennas are the biggest struggle for me rn as well as the long lead times on JLC for the EG95. Looking into Aliexpress but they’re more expensive there. Still, another few weeks should see a sample arrive. And agree on commercialization, though maybe that’s a bit easier in North America? I guess I’ll find out :sweat_smile:
The EU version cannot be even ordered there, so I had only one option. Otherwise I’d probably also just wait for the sake of simplicity.
The same seller on Taobao has an antenna that is 29mm x 9mm, barely fits within the width of an expansion card. My EG912U assembly above was tested with this exact antenna. You might need to contact the seller on Aliexpress to buy it though, since it isn’t in the product variants in this listing.
Been using the module for a day to browse internet and watch videos. Seems stable so far.
Interesting, but I am a bit dismayed by the difference in gain to the larger antennas. This pushes me more toward placing the antenna elsewhere. The ā€œFPC 80X21 D 8DBIā€ seems hopeful as it has the cable attachment at the side, which could hide in the bezel ā€œbulgeā€ and the flat part would fit under the bottom bezel flat surface.
Based on current interest it seems there could be two order groups. One for Europe (incl. UK) - facilitated by me, one for North America. Rest of the world (currently Australia) could possibly join Europe if I figure out how to mix two module types in one PCBA order.
For North America, someone else please take the lead. (Probably should be someone outside the US, e.g. Canada, which could maybe stand a chance to send packages to the US while avoiding China tariff levels but really not sure about that. But if you order from JLC to the US, you pay the full tariff rate right away.) I can help with technical parts of the order process if need be.
I’ve assembled an EG95 board, and it can connect to the internet. Tested the same antenna as before but it doesn’t work well with the EG95, performing worse than EG912U. Using a different set of main and diversity antennas (SMA antennas) it can achieve ~24 Mbps downlink and ~7 Mbps uplink though. I can also confirm that the EG95 heats up considerably during usage.
In the meantime, if anyone wants to double-check my design before the big orders, that would be greatly appreciated. E.g. look for any potential issues I may have overlooked, double-check impedance calculations and trace widths etc. So far been using it day-do-day since I got it and seems fine but that does not mean there are some non-obvious issues lurking somewhere…
Looks okay to me. A few tracks have a questionable routing, like the RXD/TXD lines here, which could be more straight and parallel to each other:
But that probably doesn’t matter much. The VCC lines are probably much thicker than they need to be, but also not an issue.
The EG95 Hardware Design guide says The width of VBAT_BB trace should be no less than 1 mm, and the width of VBAT_RF trace should be no less than 2 mm. But of course in reality, it depends on length etc.
Using this without a case is dangerous. Just managed to break off the USB-C connector from my prototype.
If anyone feel confident they can fix that (I don’t), I can provide the board on a pay-what-you-want basis.
The pads seem undamaged.
Yeah, USB-C connectors are amazing, but the small bridge of board that holds them is often a POF. Happened to me with my original DongleHider+. Can’t fix it, but would be nice to see progress on a case+antennas, so the project can be wrapped up! Go guys! :smiley:
Probably would be also a good idea to fix it in place with epoxy. I actually meant to do that but did not get to it in time.
I’ve already prepared a 3D model for the case, will finish it up as soon as I get the prototype board.
Maybe we have to reinforce the connector with some 2 component glue?
