LTE Module?
I’m not sure if I’m posting to the right thing, but is it possible to replace the Wifi card that’s in the laptop with an LTE module?
The Framework laptop uses an M.2 2230 WiFi card. Someone will correct me if I’m wrong, but there are no M.2 2230 LTE cards. They’re mostly USB, though some are Mini PCIe. M.2 could work and should be better than Mini PCIe going forward, but they don’t seem to be made:
There is an LTE expansion card in the works:
Size is not the only issue. Wifi cards use M.2 key A or E, whereas modems use key B. Different connector pinout. Also, usually, M.2 modems need an external sim slot on the motherboard (unless one is using eSIM).
