A certain company just introduced magnetic USB-C charging port
It would be great if we could have an expansion card like that: support both magnetic cable and normal USB-C cable
I had the same thought when I saw Microsoft’s announcement! An Expansion Card that works with both the new magnetic cable and regular USB-C cables would be a great addition.
Keeping the USB-C port and exploring how to integrate magnets around it seems like a promising direction. I’d definitely support a community project to make this happen. There’s also a closely related discussion here: Mag-C Expansion Card
I think that the challenge will be to get port.. it has a different shape. without usb-c port in extension card it will be hard to do anything. Any idea where it can be bought?
What do you mean? The port is just the standard USB-C with two magnets, so it should be pretty straightforward to add Mag-C feature. What is non-standard and challenge to get is the new plug by Microsoft. Good news are that we can just buy the cable from them ![]()
Yeah I just saw this as well and I 100% agree! It should be quite easy to create a USB-C passthrough port module that just uses the currently dead space next to the port for magnets. That should be all that’s needed to get a magnetic charging port on any Framework Laptop. To imagine that Microsoft of all companies enables this…
It looks like connector is slightly thicker than a regular USB-C plug. which means that hole around socket probably is thicker too. but it is just a guess based on the photos.
I would say that you can connect standard usb-c cable to magnetic connect port, but probably you will not be able to connect magnetic connect plug into standard usb-c port.
I’m referring to this part but I might be wrong
The opposite. The part you pointed to is the thickness of a standard USB-C male end, and it tapers to thinner, it doesn’t have the retention lugs required in a normal usb c male end that interfaces with the latch inside the port to lock the cable in place as the magnets do that externally, so the port will slide in and out without any noticiable friction or need to apply force, and the tapering means it doesn’t need to be perfectly lined up to insert properly
Check this out:
