Memory Speed Compatibility (Stock DDR4)
This might be a stupid question but I am wondering if I can use the DDR4-2400 RAM from my NUC in the Framework laptop.
3200Mhz is the only speed listed in the DIY but does that mean the motherboard/cpu is not compatible with slower RAM?
Great question, would love to know this, too!
Slower ram should be fine.
Can you clarify if the framework mobo requires DDR4 1.2v or 1.35v modules. I pre-ordered the i5 version. Much appreciated thanks.
DDR4 1.2V is what we’ve tested with and recommend.
