Midplate cable location
Could anyone tell me where the midplate cable is please, so I can locate it by touch? I understand it’s over toward the right hand side.
It is on the right hand side, about an inch or 2 cm from the right side of the laptop. From top to bottom about in the middle.
It is just above the connectors for the keyboard and touchpad. It is covered with a small piece of plastic on which you can pull the cable.
OK… I’m in! I’ve got the midplate out!!
