Additionally, if I were instead to buy a USB-C hub with a built in MST hub, should I be able to run KVM through the one USB-C port, I am aware it has USB2.0 but I am unsure if this is a good idea. I will definitely be using the separate NIC and USB ports for file transfers though ^^
This way I can have a pseudo-docking setup with three monitors, and only one port required (I am ignoring charging for now)
That dongle should work, however the specs indicate that it is limited to DisplayPort 1.2 which has lower bandwidth and worse features than newer DisplayPort versions.
Instead I suggest this dongle as it supports a newer standard and also has USB ports (and an Ethernet port limited to 480 Mbps as well as a charging port, although the charging port won’t work for charging the laptop): https://www.amazon.co.uk/dp/B085VLPYDR
Yes that should work, however beware that many of those hubs will take away bandwidth from DisplayPort and try to allocate it to USB 3.0 bandwidth (which ends up just wasting the bandwidth as the port doesn’t support USB 3.0). The hub I linked above doesn’t do that and allows full bandwidth to DisplayPort (which helps ensure your displays can run at full quality).
I wanted to jump in here as I am struggling. To my knowledge, the only output for external displays for the dGPU is on the back of the dGPU. We cannot access it with any of the i/o ports on the side of the laptop.
Are you using this plugged into the back of the dGPU?
I am looking at getting one of these to plug into a KVM to have two monitors off the dGPU, then use a Caldigit or other dock, plugged into the port 1 i/o for power and peripherals. This way, when I dock my computer I have two connections to make, but it will beat plugging in two monitors, and moving peripherals around.
I can’t find any other just 2x DP1.4 MST hubs without everything else, so if I can use it as I intend that would be amazing.
Hi!
I have the MST hub plugged directly into the dGPU yes, it works perfectly.
I also use mine for mouse input, but I wouldn’t use it for anything that requires more speed over USB (like file transfer) since the port is not designed for that.
Hope this helps!
Sorry to bring this back. I bought that hub plugged it into my dgpu and plugged in two DP1.4 monitors, and only one works at a time. Do you have any recommendations?
Hi, I have noticed that my monitors struggle with 144Hz through this hub even though they support it, so I would not be surprised to learn that there is a bandwidth limitation here. I run my two 1080p monitors at 120Hz instead and that works as you would expect. It is possible that you’re running into a bandwidth issue here, what happens if you try changing refresh rate or resolution settings on your monitors?
Happy to provide specs for my setup if you think that would help
Thanks for the reply. I was able to get it working but I have to disable the built in monitor and set both to 4k 30hz. Might try to see if I can find a better MST USBC hub.
