Hi everyone!
I just got my DIY edition and set up is going ok. I’ve installed Fedora 35 and use i3 for my window manager. I plugged in my USB-C dock and I’m having trouble setting up my external monitors. Here’s my xrandr output:
Screen 0: minimum 320 x 200, current 4480 x 1440, maximum 16384 x 16384
eDP-1 connected primary (normal left inverted right x axis y axis)
2256x1504 60.00 + 48.00
1920x1440 60.00
1856x1392 60.01
1792x1344 60.01
2048x1152 59.99 59.98 59.90 59.91
1920x1200 59.88 59.95
1920x1080 60.01 59.97 59.96 59.93
1600x1200 60.00
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-4-1 connected 2560x1440+1920+0 (normal left inverted right x axis y axis) 527mm x 296mm
2560x1440 59.95*+
2048x1152 59.90
1920x1200 59.88
1920x1080 60.00 50.00 59.94 24.00 23.98
1600x1200 60.00
1680x1050 59.95
1280x1024 75.02 60.02
1280x800 59.81
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 75.00 60.00 59.94
720x400 70.08
DP-4-2 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 600mm x 340mm
3840x2160 60.00 + 69.98 30.00
1920x1080 60.00* 50.00 59.94 24.00 23.98
1680x1050 59.95
1280x1024 60.02
1280x960 60.00
1280x800 59.81
1024x768 60.00
800x600 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 60.00 59.94
720x400 70.08
As you should be able to see, DP-4-2 should be able to support a higher resolution, but when i run xrandr --output DP-4-2 --mode "3840x2160"
it fails with xrandr: Configure crtc 2 failed
. I think i’ve seen a similar issue on machines that didn’t have the capability to support that many high resolution monitors, but my understanding is that the framework laptop shouldn’t have any problem. How can i troubleshoot this? obviously I’m glad to add any logs that could help out here. Thanks!
