12th gen DIY edition
I’m not able to run my external monitor at it’s native resolution via the framework extension modules.
The monitor is a Dell U2518D via HDMI via the Framework HDMI module.
I also tried to connect by the Framework DP module (and a DP to DP cable) but this combination is not working at all.
HDMI results:
2560x1440 Native resolution (not working)
2048x1080 works
1920x1080 works
Using a simple USB C to HDMI adapter works without any issues.
OS: fedora 37 via xorg
Outputs from xrandr:
➜ ~ xrandr
[internal display...]
DP-1 connected 2560x1440+2256+0 (normal left inverted right x axis y axis) 553mm x 311mm
2560x1440 59.95*+
3840x2160 60.00 50.00 59.94 30.00 25.00 24.00 29.97 23.98
2048x1080 24.00
1920x1080 60.00 60.00 50.00 59.94
1920x1080i 60.00 50.00 59.94
1600x1200 60.00
1280x1024 75.02 60.02
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 75.00 60.00 59.94
720x400 70.08
xrandr with USB C hdmi adapter:
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 553mm x 311mm
2560x1440 59.95*+
3840x2160 30.00 25.00 24.00 29.97 23.98
2048x1080 24.00
1600x1200 60.00
1152x864 75.00
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
720x400 70.08
Any ideas?
