I recently received my Framework 13 13th gen intel.
I am running linux Ubuntu 22.04 with the XFCE windows manager.
I try to connect any external monitor via the HDMI port and it sometimes is detected, and sometimes is not.
When detected, I cannot mirror displays.
I have tried putting the HDMI card in various bays with no change
I am at a loss as to how to proceed.
Any help would be greatly appreciated.
Thanks
this is the output of xrandr
I don’t understand why the montior is seen as DP and not HDMI ??
$ xrandr -q
Screen 0: minimum 320 x 200, current 1579 x 1052, maximum 16384 x 16384
eDP-1 connected primary 1580x1053+0+0 (normal left inverted right x axis y axis) 285mm x 190mm
2256x1504 60.00*+ 48.00
1920x1440 60.00
1856x1392 60.00
1792x1344 60.00
2048x1152 60.00
1920x1200 60.00
1920x1080 60.00
1600x1200 60.00
1680x1050 60.00
1400x1050 60.00
1600x900 60.00
1280x1024 60.00
1400x900 60.00
1280x960 60.00
1440x810 60.00
1368x768 60.00
1280x800 60.00
1280x720 60.00
1024x768 60.00
960x720 60.00
928x696 60.00
896x672 60.00
1024x576 60.00
960x600 60.00
960x540 60.00
800x600 60.00
840x525 60.00
864x486 60.00
700x525 60.00
800x450 60.00
640x512 60.00
700x450 60.00
640x480 60.00
720x405 60.00
684x384 60.00
640x360 60.00
512x384 60.00
512x288 60.00
480x270 60.00
400x300 60.00
432x243 60.00
320x240 60.00
360x202 59.99
320x180 59.99
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected 1920x1200+1579+11 (normal left inverted right x axis y axis) 0mm x 0mm
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
1920x1200 (0x75) 154.000MHz +HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 74.04KHz
v: height 1200 start 1203 end 1209 total 1235 clock 59.95Hz
I would send a message to support if you haven’t already, there is a chance that you have a bad HDMI card.
As suggested above, please open a support ticket. Please indicate if you’re using a hub or dock or similar to connect the device.
If this is a direct connection to a hdmi expansion card, please indicate this as well.
Framework support responded quickly with a procedure to test. It turns out that the problem lies in the XFCE window manger used by various Linux distros.
I was able to work around the issue, but am now considering changing distros to avoid this problem altogether.
Thanks again for you support!
Glad we have a solution for you. ![]()
