Hi everyone, not sure if this is a FW issue or a Linux issue. This is my first Framework Laptop and my first time installing Linux.
I am trying to connect my MG278Q Asus monitor to my FW Laptop but the monitor isn’t showing in the Displays tab of Ubuntu.
Things I’ve tried:
- HDMI to HDMI with two different cables
- USB-C to Displayport
- HDMI to HDMI on a different display
- All four expansion ports
- Updating my Bios
- Updating my Kernel
- Sudo Apt Upgrade
I am very puzzled on why nothing is working - not sure if it is a Linux issue or if it is a FW issue. The expansion ports do seem to be working with other devices such as a mouse and usb drive.
OS: Ubuntu 26.04
FW 13 AI 300 (AI 5 340)
Thanks for the help
Does the monitor work with any other computers/phones you have? It not working across both USB-C and HDMI is odd - I would wonder if the monitor is at fault. Do you happen to have another monitor to try with your FW?
Finally I wonder if there might be some detection, but some security thing in Ubuntu is stopping it being advertised to apps and your desktop. Can you run dmesg --follow and then plug/unplug the monitor via USB or HDMI? You might get some system logs that explain what the issue is.
Yeah, I grabbed the monitor from my desktop that I regularly use.
I just plugged it into another monitor and something interesting happens. My monitor is recognizing that something is trying to connect - when I plug it in, it will flicker on from a black screen, say “hdmi no signal,” then flicker back off to a black screen. Something odd on the output end of the laptop.
Nothing pops up in the system logswhen I run dmesg --follow and I unplug and replug my HDMI.
I do notice on the top right of Ubuntu the icon that indicates that something was plugged in, but no cigar.
OK, good testing.
Also try another HDMI/USB cable - I’ve had both not work for me. Some USB cables for example can only carry power or USB 1/2, and don’t have the shielding or connections to carry video.
Finally, see if xrandr gives you anything. It may require a monitor to be fully detected before it will give you any screen res information, but it will be harmless to try.
I finally got something on the “dmesg --follow” command.
Seems to see it.
“xrandr” just shows the internal monitor.
Using USB-C to Displayport gave me this:
I’m thinking of reformatting a new ubuntu or fedora on the laptop but I’m not entirely sure that will fix it.
Aha, super. Put that text into your new web search query or AI question, and see where that gets you next.
Solved it.
After a back and forth with ChatGPT, essentially proposed that it was likely a kernel and Ubuntu 26.04 issue. I switched to Fedora 44 and the second monitor was immediately recognized.
Brilliant, well done. I think it might have been solveable on Ubuntu with some more investigation work, but if you’re equally happy with Fedora, case closed
