My wifi cards white cord keeps falling off
is there a way to keep it on like a cover or something
Did you break the connector? They can be fragile.
I don’t think so if
I might try taping it down or trying to get a friend to 3D print a cover
There should be a metal cover over the connectors. See steps 7 and 8 here: Framework Laptop DIY Edition Quick Start Guide - Framework Guides
damn i don’t have that I wonder if they sell replacements
I’d reach out to their support team about it. Was yours a pre-built or a DIY? As shown in the first picture of step 7 of the quick start guide, the antenna cables should have been held down under the metal cover before you connected the wifi card. If you are missing the cover, are you missing the screw as well? To be safe, I’d check that they aren’t loose somewhere in the machine. Good luck, hopefully you get it sorted out before too long.
nah i just used a piece of painters tape its all good now i had the screw
