Hi, pals!
Tinkering with my first FW13 and a bit stuck on the Wi-Fi card.
The product description for the bottom cover kit says a Wi-Fi bracket should be included.
But I can’t find it.
Any suggestions? Incomplete kit?
There should be a bracket, wifi module and two antenna cables (black and white). I don’t see any of those in your photo…
EDIT: those things should come with Framework Laptop.
In case of Bottom Cover Kit, you should get a bracket…
Thanks! So your suggestion is that the product page for a Bottom Cover Kit contains incorrect information about the set; in reality, this kit does not contain the bracket? Thats sucks in that case. Because I can’t find the bracket on the marketplace.
Nope. Sorry for being unclear ![]()
Kit should contain a bracket - it’s even in the photo on the product page.
The best way out would be probably sending a message to Framework support.
If you have a 3d printer, you could print one. Just to get you going faster than waiting for one through support. thingiverse.com/thing:6950471. These days, many local libraries have 3d printers. If you are also missing the wifi module’s screw, there should be a number of different spares in the frame. I believe it’s a gold colored one for wifi, ssd, or audio board.
Welcome to the forum, by the way. Sorry it’s an issue that brings you here first.
Thanks! This is a good one. Print it out - the solution.
