I’d like to get a carrying case crafted for the tool and expansion cards that come with the Framework 16, but I forgot to take the tool (screw driver) with me. Returning home to fetch the tool is not an option.
Can anybody measure its circumference and length for me, so that I can make a paper tube?
Thanks
Diameter is 10mm and length is 137mm with the tip installed and 123mm without.
Mine looks exactly like this one:
Maybe not. Mine has a lost a little bit on the spudger side (broken off using excessive force, probably). Didn’t expect it being so much, though. FW16 batch 8, April of 2024 for Germany.
Thanks, this should be enough for what I need
