Hi everyone. I just received my Framework 16 on 14th March 2025.
I just want to warn any folk who may be new or inexperienced when it comes to assembly or disassembly of things like a laptop with tiny Torx screws like those found in the Framework 16.
The driver I got with my laptop was either the wrong size or of poor quality (or both).
A proper driver will fit into the head of the screw and you will fell/see it slide all the way into the screw, probably about 0,4mm or so.
The driver I received did not slide into the head at all!
I managed to get all the screws loose but my experience told me that to try and screw them back in would be a recipe for disaster. because the driver did not fit the screws, the screws would tend to not go in straight and had I continued I absolutely would have cross threaded them not to mention that to get the driver to turn a screw at all I had to press really hard. This too is a very bad idea as you risk bending and damaging the very fragile pcb below.
If you are a noob at this sort of thing and are struggling with the screws, it is not you. The driver is likely bad. Stop before you damage things and as much as you, like me, are likely dying to build your machine, don’t!
I can recommend and iFixIt driver set. They have a bit that fits the screws perfectly and make the job a breeze.
If you can’t get hold of an iFixIt set, just scrounge around for a small Torx set and you should be good to go.
I have contacted Framework support to let them know that they have an issue. I would encourage anyone else who has experience this to do the same so that they know if it was just me that got unlucky with a single poorly manufactured driver bit or if they perhaps have an entire bad batch. You will be helping other folk who are perhaps not as savvy as yourself.
I hope I was just unlucky with one bad bit.
Good luck and remember the golden rule - DON’T FORCE IT!
Oh, everything else just worked. I have Ubuntu running on a lovely machine. Super easy to install. Ubuntu even recognized I had a Framework! Great! I am loving it so far!
-Dennis
