I just got my new Framework 16 laptop with the Radeon RX 7700S graphics card. I tried to download and install NMS along with some other games. All of the other games have worked. But NMS immediately errors. I will add the error below. This is what I have tried so far:
Going to the website listed on the error and following the steps.
Drivers. I have updated them ALL from Radeons website as well as Frameworks website.
OS Updates. I do not have any further updates for Windows 11.
Uninstall/Reinstall the game and Steam.
Many, many, MANY, restarts.
An older thread said I could try moving a .DLL file from one folder to the Windows folder. (?)
Certain forms of prayers and rituals.
At this point, I am desperate for any other help or advice. Has anyone else ran into this issue with other programs?
Hi Jared,
I tested the game on my FW16 + 7700S Fedora 39, via steam, no issues. Not the same OS, so many differences.
How about opening a case at hellogame ?
In your Steam settings, you could try to change the server location that you download from to somewhere else. I’ve seen game files get corrupted at a local cache that I had to force it to download from elsewhere.
Although, come to think of it, I think the corruption problem was caught during download causing the download to fail repeatedly until I forced it to a geographically more distant server.
Regardless, sorry you’re getting no joy. It runs very nicely on the 16.
It’s noisy, truely, but with my headset I do not hear anything. Not for people with hearing sensivity I suppose. It’s my first “gaming” laptop, I cannot compare with other gaming laptop.
At those settings, every laptop sounds about 50 dB. The good thing would be to see it at 1080p 60 fps. If the noise was 34 or 35 db it would mean that they have done a good job.
I had the same error. What got it working for me was changing the “AMD SmartAccess Graphics” setting to “Hybrid Graphics Mode”. Try it and let us know.
I don’t know how or why. But I fixed it by changing the setting files:
\steamapps\common\No Man’s Sky\Binaries\SETTINGS\TKGRAPHICSSETTINGS.MXML
to:
It now launches just fine and looks GREAT! Thanks for your help everyone!
Ok I see what was changed now, the resolution in the config was set to 0, manually setting the resolution in the config fixed the issue with the game not starting.
Changed this specifically in No Man’s Sky\Binaries\SETTINGS\TKGRAPHICSSETTINGS.MXML:
The game would then finally start up.
I did also have to switch to Hybrid Graphics in AMD Adrenaline Software otheriwse it would show up in a small window only.
Wow, thanks! I’ve been playing blade and sorcery and bonelab with little issues and wondering why NMS VR wouldn’t even load. I’ll try this when i get home!
Hey all, sorry for necroing this post. I went through all the steps outlined in this post and now I can get NMS to launch, but it doesn’t appear? Like, it’s clearly there and running but it doesn’t post any graphics to screen. I can hear it when I alt-tab to where its supposed to be, but again, no graphics.
This occurred after the first time I got it to launch and it immediately crashed my whole computer. A restart briefly fixed it, and I assumed it was fixed but since then the not there issue has cropped up again and I once again cant seem to get to play NMS.
FW 16 Stats:
Windows 11
Ryzen 9 7940HS
Radeon RX 7700S
32GB RAM
Certainly more than enough storage space (2TB + 500GB)
UPDATE: Did some more digging and uh, I figured out what was wrong. For some unholy reason NMS split itself into two pieces in the AMD graphics control panel? I dont know why, how, or when, so just something to watch out for.
In case anyone else finds this thread because of the same problem. I “fixed” my issue with a lot of trial and error, but the parts that seemed to have an effect for me were:
@Michael-R’s changes in No Man’s Sky\Binaries\SETTINGS\TKGRAPHICSSETTINGS.MXML.
Right click on the desktop to open AMD Adrenelen and setting No Mans Sky to “AMD SmartAccess Graphics”=“Hybrid Graphics Mode”.
Going into Windows 11’s Settings for Graphics, and setting No Man’s Sky to a GPU preference of AMD Radeon. (This is the one that seems to keep No Man’s Sky within the bounds of the screen. I think because it swaps the GPU before No Man’s Sky launches.)
I also did a lot of playing around resetting the screen resolution while the game was running to get it back within the monitor region and playing around with smaller resolution in the TKGRAPHICSSETTINGS.MXML file.
Note that trying to set fullscreen to true caused the crash error, as did leaving the ResolutionWidth and ResolutionHeight as 0.
Now I’m actually going to load a game and see if the performance is better than when I was running Bazzite.
New issue I’ve found (at least with dGPU). No Man’s Sky works fine with the above tweaks until an in game screenshot is taken, at which point it completely freezes with the screenshot never being recorded. Would be an inconvenience for most but many missions (including during the current expedition) require the player to take one. Have tried changing AMD and NMS settings to no avail.
